Girling brake caliper with a lip
  • vincecaporale3
    • Nov 2015
    • 6
    I want to change the brake pads and rotors on my 1990 E30, but the rotor has a lip around the outside of it(guessing they have not been changed in a long time, if ever) that won’t allow me to remove the caliper because I can’t get the pads over it. Any ideas what I can do next?
  • turbo55
    • Jul 2014
    • 223
    Couple of options:
    1. (assuming you already took out the bolts holding the calipers) Pull the caliper hard against the rotor. Then try taking it off. What you're trying to do is by pushing the caliper you're pushing on the brake pad which in turn retracts the piston.
    2. If you're definitely throwing away the old rotor, just take a file or a grinder to the lip.
    • vincecaporale3
      • Nov 2015
      • 6
      Reply
      Yeah, pulled the bolts. Though about grinding the rotor. I will give that a try.
      • e30davie
        • Apr 2016
        • 1788
        A nice chunky screwdriver between the edge of the brake rotor and the inside of the caliper as a lever to get it off. will probably wreck the pads but you are replacing them anyway?:D
        • Todd Black 88
          • Oct 2007
          • 3449
          Ahhhhh.........have you pushed the pistons back into the calipers yet? You should have loads of room.
          Originally posted by codyep3
          I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
          2001 silver/Blk 325 cabby. SOLD
          2002 325xit Sil/blk. SOLD
          2010 F650gs twin
          • DrJosh
            • 2011
            Use a big c clamp to retract the piston. One foot goes on the back of the caliper, the other on the outside pad. The piston will be retracted enough to pull the caliper and pads off the rotor.
            Originally posted by Sonny
            I am a meme for our community.
            • AndrewBird
              The Mad Scientist
              • 11897
              Like e30davie said, use something try pry the piston in. Since you are replacing the rotor and pads, no need to worry about hurting them.
              • vincecaporale3
                • Nov 2015
                • 6
                Girling caliper continued
                Soooo, was able to remove caliper by swing the caliper up and out of the way. Was under the mis-impression I could remove everything as a unit by removing the 17 mm bolts. Wrong, I needed to pivot the caliper first to remove the pads, then removed the carrier. Thanks to everyone for you input.
