Subframe Won't Come Down!
  • jgilber0
    • Nov 2016
    • 457
    Glad you got it. What a PITA. Thanks for sharing the solution.
    I’ll be doing mine at some point, hoping it will be easier on my car.
    Jon (OO=[][]=OO)
    1992 325ic white, stock with a 5-speed swap
    Palm Beach County
    • Pootis
      • 636
      After reading my explanation I see how it sounded like I was saying go from the top. You did it the exact way I was trying to explain it. Glad you got it out. Sending a bolt in the bottom is the easiest way of getting it done I feel.
      1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
      COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
      • george graves
        • 19998
        PB blaster. Drench everything in it like you're Ron Jeremy.
        Originally posted by Matt-B
        • jeffnhiscars
          • Jun 2011
          • 6011
          My first one was like this one...took days. For me it was the 5/8 tap, threaded rod and 3 vicious whacks of a slide hammer.
          Last one just fell out when I unbolted it.
          Welcome to e30 world....and George has it right :)
          Alice the Time Capsule
          • haaken675
            • Sep 2016
            • 601
            So, if this method doesn't work, then what?...I am in the exact same boat, except mine wont come out PERIOD...My subframe bushings snapped into the body when my buddy and I took the subframe down and both sides are being complete bastards...I used 5/8 bolts and have been beating on them for days now with a sledge and NOTHING...Has anyone tried using a drill the size of the sleeve itself and just drilling it out? I'm worried about hurting the body.
            • noid
              • 1536
              Get a proper air hammer, and hit it from the top into the bolt.
              I recommend "big nasty":
              If you're on a budget, get this, dollar per power is insanely good with the 7150:
              Otherwise, drill it out, just go slow, and make sure not to go too far. As the picture illustrates, you dont want to drill into the 'seat for subframe bolt" black (car) material.
              You should be able to tell from the top just how far/close you have drilled.
              Once its mostly drilled, you can use a cold chisel and it should start to spit apart/fall out.
              Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
              Your resource to tools and tips: www.rtstools.com
              • haaken675
                • Sep 2016
                • 601
                I'v been considering an air hammer, but I already managed to punch the 5/8 bolt out once and im a bit tired of wasting money on tools that aren't working. I'll look into getting the Chicago pneumatic one and see what happens. It's getting frustrating as I feel like this one thing could literally ruin the car and waste all the money I have into it at this point.
                • noid
                  • 1536
                  Just drill it out then, a drill bit and cold chisel are cheap.
                  A stuck bushing is hardly reason to worry about a whole car becoming trash.
                  Just remember, you're not the first or last to be in this situation.
                  • haaken675
                    • Sep 2016
                    • 601
                    I just have worries of drilling too much and ruining the mounting point. I have had an e46 in the past with torn subframe mounts so I get slightly paranoid about subframes on bmw's...
                    • haaken675
                      • Sep 2016
                      • 601
                      Well, tried the air hammer and just managed to strip out the lag bolt and knock off all of the external bits that were hanging on, so looks like ill be drilling out the sleeve now. Wish me luck.
