Okay, I've searched and done research and all that jazz, but I need to know what company makes what camber adjustment kits that will allow the most Positive camber adjustment.. the most I've seen is only 1/2 degree positive adjustability, and I need more than that I would think because this car is a DD and I also have to drive it to NC in a month, and My tires just wont last that long as it is..... any help would be greatly appreciated, but I need to know asap so that I can order them now so they can go on the car in time for the trip to NC.... THANX!
Camber help ASAP!!
have you checked out the toe in? excessive toe in will wear tires far faster than excessive camber.My 2.9L Build!
Originally posted by Ernest HemingwayThere are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.Comment
I drive my car daily with 3.5 degrees negative camber up front. With zero toe, uneven wear isnt bad at all.
Check the toe.Comment
Is this the same for the rear? I have IE's kit out back (camber and toe) and was curious as to what the rear settings should be. As close as I can to OE spec or a little different? car is DD.Comment
