Adjustable Camber/toe bolts backing out
  • pilot_anderson
    • Aug 2015
    • 37
    I have AKG rear camber & toe adjusters.
    Ever since install I have had issues keeping alignment/keeping rear trailing arms bolted. It is VERY SCARY to be on the highway to realize an eccentric has just backed its way out. I have had this happen twice now. 4 wheel alignments are not the cheapest thing either. I wanted an adjustable rear suspension, but not one that was dynamic in its adjustability!
    Has anyone else dealt with this?
    Can I tell the alignment shop to use some red thread locker? -or blue? assuming I'd need the tough stuff.
    Can I get a professional to put a safety wire hole in these bolts? That should stop them from backing out.
    Maybe the bolts are just too short? Happy to hear all suggestions.
    TIA
    02/1992 E30 Cabrio
    02/1989 E34 535iS
  • SkiFree
    • Jun 2011
    • 2766
    If memory serves, the AKG adjusters utilized bent brackets instead of machined brackets. This meant that the washers were not sitting snug into the bracket (there's a number of old threads on this if you look).
    Hence why a large number of people used the IE adjusters. It's not a perfect system still, but it's an improvement over the AKG setup. A more robust adjuster is the Posi-loc style adjuster from IE.
    ADAMS Autosport
    • e30davie
      • Apr 2016
      • 1788
      What sort of nuts are on the other end? Id be putting some decent nylocks on.
      and if you are a really concerned drill a small hole in the bolt past the nut and put a split pin through it, then it cant physically come out.
      • ColinGreene
        • May 2012
        • 16
        I used garagistic parts and they have been solid, I did however replace the locking nuts when i did the subframe exchange.
        • pilot_anderson
          • Aug 2015
          • 37
          Nylocks are a good idea and prob what Ill be doing next.
          The nuts and eccentrics are from a BMW X5. The ones currently installed are new.
          # 33-30-6-786-186 (washer) and #33-32-6-760-668 (nut)
          02/1992 E30 Cabrio
          02/1989 E34 535iS
