Hey guys. While swapping in my stainless steel brake and clutch lines, I ended up with two issues. The front passenger hard line was so corroded that the fitting stripped out and I couldn't actually get it off. Same thing happened with the clutch line. It looks like someone had previously removed them and likely stripped the nuts and used something like vice grips in order to get them tight enough.
I found the part numbers for the hard lines on real oem and looks like a few places carry them. The pictures just show straight lines that being said. Do the lines come pre bent, or should I just go about making my own? I feel like if I have to bend them myself as is and purchase a small tube bender, I might as well just make them myself.
