Rear end rebuild
  • Dr Skillet
    • Jun 2018
    • 48
    Rear end rebuild
    Removed rear parking brake assembly and looking at hub and bearings and they have no play or noise. Question...Do I replace anyway since its a 32 year old car and they are original or do they have yearsss left in them? Taking down the entire subframe and sand blasting and painting and basically replacing everything else on "Rusty". Also can I take differential down with subframe as I am not sure I am going to be able to get top 4 mounting bolts off due to rust. I have half shafts off!
    Thanks
    Mark
  • jbontke
    • Mar 2019
    • 449
    If you are going to restore the subframe, why skimp out and run bearings that you don't know much about? I am not sure about the diff.
    • citizen_insane
      • Jan 2013
      • 216
      The diff will come down with the subframe. I agree you should replace everything you can while your'e in there if you can afford to. It's so much work to pull the rear subframe that I highly suggest doing everything to it:
      • Alignment Adjusters
      • New Bearings
      • New Bushings
      • Reinforced rear arms
      • New diff seals
      • New rear brakes (and parking brake shoes)
      • Painting everything up like you mentioned (POR15 is the best way to do this)
      • Andre3127
        • Dec 2017
        • 291
        Yes, the differential and subframe can come down as one unit, but it's a lot heavier that way. You can remove a fully assembled subframe by yourself, but have some help lifting it back into the car.
        Budget E30 Parts - Used and Reconditioned parts for your BMW
        • Aleman
          • Mar 2012
          • 1607
          Can't you use a floor jack to lift the assembly up into the car? I'm about to do this big project, so if that's not an option, I'll need to do more planning. Thanks
          R135 /// 1990 Alpinweiß II 325is
          └┼┼┘ /// 1993 Black/Black Convertible (sold)
          ..24
          • Andre3127
            Andre3127 commented
            Editing a comment
            Sure can, but balancing it on the bottom of the differential on instillation can be tricky. Mine fell off several times.
        • jeffnhiscars
          • Jun 2011
          • 6011
          Ive done 2 sub frames and both times installed it with the diff and trailing arms already in place. Its a bit of a balancing act but manageable with a floor jack. I also left the drive shaft in place so had to fiddle to get everything aligned...drive shaft first with the subframe tilted back then up for the chassis bolts. An extra pairs of hands really helps and before you tighten the TA bolts measure from the axle center to the fender (before and after) so you dont preload the bushings.
          Alice the Time Capsule
          • Zambuzan
            • Nov 2017
            • 434
            This only applies to OEM rubber bushings, right?
            "Time doesn't heal anything... It just teaches us how to live with the pain." - My Cracked Dashboard
            • jeffnhiscars
              • Jun 2011
              • 6011
              I've only ever used rubber.
              • Aleman
                • Mar 2012
                • 1607
                Good thing I have two kids that are nearly adult-size to help me out. Thanks for the info, gents.
                ..24
