Rear Brake Fittings Rusted - Opinions Welcome
  • rfordo
    • Dec 2018
    • 22
    Shocker, the below photos are coming from a Chicago based e30 for its lifespan. The majority of the body has been saved from the rot too bad but the undercarriage components thats another story.
    I have my tank out in the process of swapping a spectra replacement and all new fuel lines thanks to similar rust. While working to replace the lines to the engine bay I sprung a main brake line leak. This system needs addressing and replacement as well.
    I am wanting to remove the entire rear brake line system and swap in a chase bays kit or OEM replacements but I am leaning towards the former.
    My question is, I have soaked these fittings a few times now with PB blaster before even attempting to put a wrench on (yes I have correct brake line wrenches). I would love some guidance on how to tackle these fittings, I can try heat but they are so beyond corroded I am doubting my abilities. Would a shop charge an arm and a leg to simply remove the whole system (I could instal the replacement)?
    Anyways, heres some rust porn for you freaks out there.
  • Andre3127
    • Dec 2017
    • 291
    I was in your same boat. I ended up cutting all the lines and replacing them with copper nickel and stainless braided lines. I used a T fitting from a VW, which was found below.
    Brake lines don't come looking like they have tree bark. I'd replace all of it asap.
    21 likes, 1 comments - Andre Gross (@e30b25) on Instagram: "Old vs. new. #e30 #325e #325i #bimmer #bmw #bimmergram #brake #brakeline #amazon #metric #bubble..."
    18 likes, 0 comments - Andre Gross (@e30b25) on Instagram: "Brake line #e30 #325i #325e #bimmer #bme #bimmergram"
    https://www.amazon.com/PREMIUM-METRI...69697311&psc=1
    Budget E30 Parts - Used and Reconditioned parts for your BMW
    • rfordo
      • Dec 2018
      • 22
      Originally posted by Andre3127
      Thanks for the reply. How would you suggest cutting off the fittings and lines? I have a dremel and cut off wheels I could use.
      Would I cut around the fittings and be able to save the brackets?
      • AndrewBird
        The Mad Scientist
        • 11898
        I'd try breaking them lose first. If you end up rounding them off, you can always cut them then. If you cut them close to the fitting, you can put a deep-well socket on it for more bite.
        • Sunnyledge
          • Nov 2017
          • 221
          Since you’re going to replace them, a little heat will help in separating the fittings. But with with all that PB Blaster get ready for some smoke. (Beware of smoke alarm).
          • Sunnyledge
            • Nov 2017
            • 221
            There is some value in removing them intact. They will serve as a template to pre-bend the replacements giving you a 95% solution.
