Brake pad wear sensor wiring
  • bignslow
    • Oct 2017
    • 142
    When I got my E30 it was missing brake pad wear sensors. I got them replaced and all was well for a bit until this morning on the way to work when the light came on out of the blue. I discovered that front sensor wire rubbed through on the wheel and broke.
    Is there a certain way the wires need to be routed to they don't come in contact with the wheel or should there be a clip holding them in place?
  • jeffnhiscars
    • Jun 2011
    • 6011
    The rubber grommet slips in to the tab on the strut housing pointing up, then to the wheel hub. These lights are notoriously random so I just take the new sensor and tie it in a knot attached to the strut just to keep the light out. Actually monitoring pad wear should be easy enough without sensors if you work on the car yourself.
    Alice the Time Capsule
    • bignslow
      • Oct 2017
      • 142
      Ok thanks. I do all the work myself but like having all the components functioning as they were designed at the factory.
