Weird Brake Issue
  • ryan.of.peachey
    • Apr 2019
    • 77
    Weird Brake Issue
    '88 325i vert. I'm not getting any fluid to the back of my car. I've got the subframe out to replace the rear brake lines and all the bushings, etc., and there isn't any fluid leaking from the lines while I removed them. The brake pedal is very firm like everything is hooked up, yet there are open lines. Do I have a clogged brake line or is it likely something else?
    Sent from my SM-G960U using Tapatalk
    1988 Alpinweiss 325i Convertible
  • Northern
    I like cupcakes & sh!tboxes
    • 5270
    probably a clogged or pinched line. Could start disconnecting the rear lines at various points to try to isolate where the problem is.
    Originally posted by priapism
    Originally posted by shameson
    • ryan.of.peachey
      • Apr 2019
      • 77
      I'm going to unhook it from the brake pressure regulator and see if anything comes out there...
