This sounds like the same mistake people make in replacing their FCABS. Using WD40 or some lub, grease, white litium, etc to get the FCABs back on the control arms. BMW states to use soapy water....ONLY to lub up the bushings and CAs. If you use grease or lub, the bushings never "bond" to the control arms and they can slide around, changing the suspension geometry.
As far as the subframe bushings, sounds like the same concept happen when you lowered the weight onto the jack stands. Being all slick still, with the soapy water, it pushed the bushing back "out".
Sounds like you fixed the problem though, good for you. Something Ill have to remember myself and tell my shop guys cause their putting SFBs and RTABs in my 90 i next week.
Nice catch!!
