Another rear subframe thread.
  • txtorquemade
    • 1758
    #106
    Originally posted by FredK
    I pulled the subframe and the aluminum cylinder was around the same height as the bore it's supposed to fit in, especially with the thick washer.
    The only thing I can think of is that the bushing was installed with some soapy water, and by putting the jackstands on the subframe, forced the subframe to ride up on the bushings before the soapy water dried up.
    I pulled the bushings back into their bores so that there is no protruding material and the flange was butted against the bottom of the subframe. I then reinstalled the subframe. Pure joy. At least this time I dropped it really quickly and reinstalled it quickly.
    I'm going to let the bushings settle overnight, and hopefully they won't budge when I set the car back down again. Otherwise I'll just drive my car off a cliff. :mrgreen:
    This sounds like the same mistake people make in replacing their FCABS. Using WD40 or some lub, grease, white litium, etc to get the FCABs back on the control arms. BMW states to use soapy water....ONLY to lub up the bushings and CAs. If you use grease or lub, the bushings never "bond" to the control arms and they can slide around, changing the suspension geometry.
    As far as the subframe bushings, sounds like the same concept happen when you lowered the weight onto the jack stands. Being all slick still, with the soapy water, it pushed the bushing back "out".
    Sounds like you fixed the problem though, good for you. Something Ill have to remember myself and tell my shop guys cause their putting SFBs and RTABs in my 90 i next week.
    Nice catch!!
    sigpic 1987 325is
    • dj01540i6sp
      • Jan 2009
      • 349
      #107
      Fcab
      I use straight Liquid Dish Washing Soap ''Joy''. Amazingly they push on with very little effort. I have heard horror stories people beating them and destroying them trying to get them on. Remember to get the car set up so you can let the car down on it's wheels so they can settle in,- In the rite position before the soap dries and the rubber vulcanizes it's self to the stud/shaft. GL
      • FredK
        • 14755
        #108
        I now just use turpentine. I think it evaporates faster than soapy water or straight soap.
        • JoeyBones
          • 422
          #109
          Has anyone had experience with the actual tool to do this?
          • monty23psk
            • Mar 2008
            • 1289
            #110
            Tool makes it a breeze. I rent the tool in another thread below this one. Others have used it already and they had a much easier time.
            Alex 88 m5 | 91 318is | 19 Subaru Ascent
            BMW Tool Rentals & Fender Roller
            • JoeyBones
              • 422
              #111
              and you dont have to drop subframe when using the tool right?
              • monty23psk
                • Mar 2008
                • 1289
                #112
                Right, you just have to loosen the rear shocks from the TAs. THen you need to remove the SFB bolt and then loosen the subframe from the chassis. The tool is make to fit in the ~2" space. Of course you need to hold the subframe as a whole so it doesnt strain any lines or cables.
                • JoeyBones
                  • 422
                  #113
                  thats great....seems like the easiest for sure!
                  • monty23psk
                    • Mar 2008
                    • 1289
                    #114
                    Yup, let me know if you would like to rent it.
                    • TrentW
                      • 2815
                      #115
                      Full of good info here. I'm wanting to drop the subframe cause I want to replace the Bowden cables, swap in all 6 stainless steel brake lines and clean up & paint the subframe, trailing arms and rear calipers.
