How can I clean abs sensors????
  • Juanka
    • Mar 2006
    • 74
    Im getting problem with my abs and i read that triyng to clean the wheel speed sensors is the first option. the question is how and what i need to clean them?
    BMW 325IS 1987
    www.eurocrewpr.com
  • mikeedler
    • 6707
    guess this isnt going to help, but,
    • Juanka
      • Mar 2006
      • 74
      sorry i change it :roll:
      BMW 325IS 1987
      www.eurocrewpr.com
      • FredK
        • 14763
        Just remove the sensors by removing the 5mm allen screw holding them in, and brush off the accumulated junk on them, and put them back in.
        • mikeedler
          • 6707
          you just need an allen key, unscrew them, pull them out(hope they come out easily, and wipe them off. I really doubt it will help though, It is an electro magnet, and some dust on them isnt going to affect anything. But if your lucky, something could be cought up in there.
          clean them off with a rag, and some brake cleaner.
          • mikeedler
            • 6707
            posted at the same time.
            • Juanka
              • Mar 2006
              • 74
              thanks to both :D
              BMW 325IS 1987
              www.eurocrewpr.com
              • Juanka
                • Mar 2006
                • 74
                if there a way to test them????
                BMW 325IS 1987
                www.eurocrewpr.com
                • Mike325
                  • Mar 2006
                  • 3685
                  Drive fast on the road and slam on the brakes. If they lock up then it does not work. If they pulse, then you are good to go.
                  Originally posted by Kershaw
                  • FredK
                    • 14763
                    I believe the ABS sensor is a Hall Effect sensor. The tone wheel built into the hub of your car passes by the sensor and creates a small scale voltage. You may be able to detect this voltage using a small voltmeter capable of measuring millivolts.
                    Just hook the voltmeter to the terminals of the sensor and move the hub back and forth. There should be an indicated voltage. If not, it's either dead or you need to try a different set of terminals. I'm not sure how many pins there are on the ABS sensor.
                    • Juanka
                      • Mar 2006
                      • 74
                      the problem that i have is when i the car stop, the brake pedal push my foot out and the it goes down again to it normal level :crazy:
                      BMW 325IS 1987
                      www.eurocrewpr.com
                      • PiercedE30
                        • Apr 2005
                        • 4220
                        sounds like you may have some junk stuck in a brake line possibly......
                        My 2.9L Build!
