um i hit something..help
  • E-rich
    • Jun 2006
    • 982
    so tonight my balls got too big and i hit a solid object with my left front pretty hard. i now have a little more camber on that side. i got underneath and visually cant see anything bent or broken. car still tracks/drives straight. i can adjust it all to be even but it will bug the hell out of me so id rather fix it. any suggestions as to where/what to look at as far as common failure. from the marks on my wheel i hit about half way up if that helps any. thanks in advance guys.
    erich:(:(
    Originally posted by rwdrift
    Back to E-Rich's car and drifters. His car is baller, purpose built. Posers are fags. KA-Ts suck. I like beer. And I need monies.
    - Erick
  • Jand3rson
    • 37587
    It's possible you either bent a control arm, bent the control arm bushing bracket, or bent a tie rod end. Could be a few other things as well, but I'd check those first.
    • 1991 318is
      • Dec 2005
      • 786
      Also check the distance from the inside of the tire to the strut on each side of the car. A bent strut can appear as camber also.
      • backtrail69
        • Jul 2005
        • 4471
        Maybe check the spindle too.
        :: PNW Crew ::
        '87 325 4dr, '74 2002
        • MrK
          • Jan 2006
          • 709
          I vote bent strut. Especially with those zero offset wheels.
          This is your M20 on steroids:
          • E-rich
            • Jun 2006
            • 982
            i wont get a chance to really diagnose till tommorow so i will post as i know.
            - Erick
            • winstontj
              • Mar 2007
              • 500
              what the hell did you hit?
