Darn Balljoints
  • Apex381
    • Mar 2004
    • 740
    Darn Balljoints
    I'm in the process of installing some used control arms that have ok balljoints (not as good as new but better than the worn to hell arms I have now). I'm installing the new driver side arm but now when I tighten the balljoint nut the balljoint shaft just spins. Anybody got any idea how to tighten this down? I cant even take it off because its spinning. I'm going to have to cut the damn thing off to remove it.
    Any ideas? I'm in the middle of a complete suspension rebuild, I just finished the rear (and the subframe nightmare). I've run out of patience.
    1987 325is - sold
    2001 330i - New DD
  • StereoInstaller1
    GAS
    • 22679
    Use a floorjack to apply upwards tension on that balljoint while turning...should get that nut right off.
    GL!
    Luke
    Closing SOON!
    Thanks for 10 years of fun!
    • Mr Deagle
      • 1121
      place a jack under the offending ball joint, jack until some weight is on the ball joint seat, and tighten
      edit: i cant type fast enough, or my interntetz is the slowz
      • E30 Reaktionär
        Site Manager
        • 14451
        Yes what they said, i did this to mine the other day but i put new arms in mine.
        1992 BMW 325iC
        1978 Chevrolet Monte Carlo
        • Apex381
          • Mar 2004
          • 740
          Awesome, thank you
          I cant believe I didnt think of that but its probably because I have PTSD from the subframe job.
          1987 325is - sold
          2001 330i - New DD
          • StereoInstaller1
            GAS
            • 22679
            BAAAHAHAHAAAA!
            Closing SOON!
            • Apex381
              • Mar 2004
              • 740
              yeah the nightmare of trying to get my subframe out and then installed (during which everything that could go wrong did), and then installing the IE trailing arm bushing that fit like crap (which had better not f'ing squeek because I used a good amount of grease) made me want to hide under a trashcan and cry like an emo kid. My buddy who helped me is scared sh*tless so do his.
              1987 325is - sold
              2001 330i - New DD
              • StereoInstaller1
                GAS
                • 22679
                Fucking great...I have a spare "modded" subframe. Almost ready to order bushings (urethane TA, stock SFBs) and the IE toe/camber kit. I already braced the sway mounts, now I wanna gusset the bearing housings a bit, do the other stuff and put it in.
                Maybe this winter....
                Closing SOON!
                • Apex381
                  • Mar 2004
                  • 740
                  In the end you'll be glad you did it. My mechanic friend says it takes him 8-10 hours to do the job so thats a 560-700 dollar savings. Just make sure you have another car to drive while the e30 is layed up.
                  1987 325is - sold
                  2001 330i - New DD
                  • etxxz
                    • Feb 2006
                    • 2085
                    ^^ agree my subframe's in the floor as we speak as well as the front suspension awaiting coilover conversion... i'm waiting on parts so not to get "PTSD" i do everything a few hours at a time d:
                    i'ma go research the camber kits 'cuase everyone's scaring me about the darn camber and toe problems
                    No more e30s for me.
                    88 black BMW OBDII 332is dedicated track [sold]
                    88 BMW OBDII bronzit 332is [RIP 03/08]
                    91 BMW 325i [sold]
                    86 Corolla 'Ae86' HB 20v trd [sold]
                    http://youtube.com/watch?v=pTj7Hn9v5Rs
                    • mops
                      • Jan 2006
                      • 138
                      the hardest part i found when doing my subframe was putting it and alligning it back , so that the diffr attached to the drive shaft. It's bloody difficult cos the diffr flange has to align with the driveshaft studs... and i did it all myself and even now i wonder how did i managed to allign these... because you can't see nor manuver the thing in place.. oh well...
