Camber Q
  • MrK
    • Jan 2006
    • 709
    Camber Q
    I just got back from a 'free general checkup' that was being given at a newly opened garage/maintanence place, and the guys brought my attention to the fact that my front wheels had -2 degrees of camber, within .01 of eachother, something they'd never seen on an e30 before.
    According to them, front camber means either a damaged/bent shock tower, or worn bushings. So EXACTLY equal negative camber on both sides stumped them.
    Here's the deal. I have a strut bar, and my bushings are all new (stock). BUT, I do have e36 M3 control arms installed. Could those be giving me negative camber up front?
    This is your M20 on steroids:
    • 34835
    what exactly is wrong with -2 degrees? sounds about perfect for a street car to me...
    • MrK
      • Jan 2006
      • 709
      My bad... -2 degrees off stock spec is what I meant... so about -4 total I suppose? Don't get me wrong, it handles GREAT, but I was just asking...
      • MrK
        • Jan 2006
        • 709
        Anyone?
        • Mr Deagle
          • 1121
          If it handles good, and doesn't have bad tire wear, then leave it
          • PiercedE30
            • Apr 2005
            • 4220
            4 degrees isn't anything to be worried about. I ran -3 with my camber plates. I could go to somewhere around -6 or so....
            My 2.9L Build!
            • MrK
              • Jan 2006
              • 709
              OK thx, that's all I needed to know. I also removed the springpads from the rear to lower the car and in effect have about -4 degrees camber out back as well. The car handles like a freakin gocart now!
              • erik325i
                • Jan 2005
                • 3567
                Are you running stock springs, or lowering springs?
                -Erik
