Performance trailing arms
  • homegrone30
    • Jun 2007
    • 1449
    i was just wondering if any companys made any performance rear trailing arms.
    any clues?
  • 86espowa
    • Jun 2007
    • 296
    Lol, how do you make a trailing arm more "performance?"
    its a trailing arm, invest money in suspension.
    • PУCCKAЯ_e30ka
      • Jan 2006
      • 1226
      you can get adj. bushings (camber/caster) as far as I know
      • iflytii
        • Jun 2004
        • 482
        You can study what the old DTM racers used to do which basically boils down to the same "evolution" BMW took with the semi-trailing arm as it progressed into later year cars (reinforce them).
        Some worthwhile reading on the subject:
        http://e30m3performance.com/installs..._sub/index.htm
        However, unless you are racing there really is reason to do that.
        You can also make them adjustable by using eccentric bushings OR slotting the subframe to allow camber/toe adjustment. A worthwhile mod if you have lowered your car. Of course going to harder bushings or simply replacing the old rubber at the trailing arms and subframe mounts will help too.
        • homegrone30
          • Jun 2007
          • 1449
          you could make emm beefier or do the geometry and they could be made al sorts of different ways whether you want a wider or more narrow stance change the height camber toe all sorts of things. And i am investing in suspension thats why i was looking into this what good is shocks and spings if i kill a trailing arm.
          • Spaz
            Crazy Canuck
            • 2276
            if you want a better trailing arm, look to upgrade to m roadster trailing arms, they are A-Frames and have a beefed up knuckle.
            Cam .W '91 325is
            Spaz's 1991 Alpine White???? S52 Build Thread...
