Control Arms. i need answers
  • dj2xrated
    • May 2007
    • 540
    e30 325i coupe. i want to get a stiffer steering feelings when i drive. i am looking to buy aluminum control arms..is that a good idea or just stick with stock.
    also is there any other bolt on swap. say maybe an e30m3 aluminum control arm or e36s (if they have aluminum)????
    Operation S/C E39M5.:woowoo:
  • Van Westervelt
    • 9365
    e30 m3 is the model that had the aluminum control arms. THe aluminum arms will not give you a stiffer steering feeling though. And at 260 a side, not really a cheap upgrade. Stick with stock steel ones, get new ones, and new tierods, and some m3 poly control arm bushings.
    edit-
    You could also go with the treehouse units, or the ground control ones even.
    • Cooper
      • Jan 2007
      • 99
      Using M3 bushings in the lollipop will add more caster and that will make the steering feel slightly harder to turn.
      • Jand3rson
        • 37587
        Like Curt said, M3 control arms are totally unecessary. Get new OEM M3 control arm bushings. People greatly underestimate the stiffness of new rubber bushings. 20 year old rubber feels like mush.
        I would also check and replace your front upper strut mounts/bearings (one piece). I just did mine along with the M3 CABs, and my front end was transformed.
        • ian e30 318is
          • Mar 2007
          • 1809
          Whats the difference between the M3 CABs, the CAB with a bracket (on bavauto) and the Treehouse Racing CABs?? What are the advantages of each? and the reason for the huge price difference? thanks
          1991 LS1 Swapped 318is
          Instagram:
          https://instagram.com/saltybeast/
          LS Build Thread:
          https://www.r3vlimited.com/board/for...s-e30-ls1-swap
          • etxxz
            • Feb 2006
            • 2085
            x2. Amen to this
            No more e30s for me.
            88 black BMW OBDII 332is dedicated track [sold]
            88 BMW OBDII bronzit 332is [RIP 03/08]
            91 BMW 325i [sold]
            86 Corolla 'Ae86' HB 20v trd [sold]
            http://youtube.com/watch?v=pTj7Hn9v5Rs
