Hi everyone.
Kovs's kit is the Race kit with 11.75" x 1.25" (300mm x 32mm) Heavy Duty rotors with directional vanes for improved cooling. That's the same diameter as the e28 M5's front discs, and even 2mm thicker than M5's stuff. Calipers are the Superlite forged calipers with stainless steel pistons for improved heat barrier between the pads and the brake fluid. Those calipers are the best bang for the buck that Wilwood has to offer. They are way stiffer than Dynalite, Dynapro and Powerlite.
A friend of mine has a similar kit on his e30 344i. Yes an e30 with a 4.4 V8, running on full slicks and he never came close to the limit of the brakes.
Be aware that as long as you have 2mm clearance all around you should be okay. Nonetheless, if using Team Dynamics Pro Race 1.0 wheels, you will have a lot more clearance. How to recognize real 1.0? They have the spoke portruding a bit beyond the face of the wheels. They have no real lips, and the brands is a sticker on the rim, it's not cast. Several shops will pass some newer 1.2 as 1.0 and you should really insist on the 1.0 that are also a bit lighter.
Please note that Mike B. has a great aluminum pedal cluster adapter for those of you who opt for some Tilton MCs and go boosterless. That would complement the system pretty well if building an all-out racecar. On this subject, I may add that calipers with 1.75" pistons will have a lot of hydraulic power, which is great if using a boosterless system, and/or a rear race kit (coming soon) with quad 1.00" pistons.
Most everyone may opt for the smallish 1.38" pistons as it allows to have stock diameter MC, even reduced travel and proper front/rear balance with stock rear set-up. Several of my customers opted for the 1.38" front calipers on their Sport kit (11.75" x 0.81" rotors) and have smiles ear to ear at track events.
Hopefully, next year, if cashflow permits, I will have more brake products for e30s. BTW If you have a shop/distributorship and want to distribute Massive products, then let's talk. I have about a dozen more products that I am awaiting to manufacture as I need more cashflow
So don't be shy and have a look at the Summer Sale before the price hike.
