need new brakes
  • jrobie79
    • Mar 2006
    • 2526
    need new brakes
    lookin to get all 4, with rotors and do my e-brake as well which has been sucking, whats the best economical setup that doesnt squeal too much? i really dont wanna spend a fortune.
    1991 318i ---- 308K - retired
  • Spec
    • Dec 2005
    • 320
    No idea but I'm going to be doing the same thing on the same car. Best of luck.
    1991 BMW E30 318i sedan
    2005 Kawasaki 636cc ZX6-R
    PNWRiders.com
    • e30lyf
      • May 2007
      • 4552
      ATE or BREMBO rotors, HAWK HPS or MINTEX pads, im running brembo (oem) & mintex pads.
      - Fercy -
      Classic BMW Specialists
      Santa Clarita, CA
      www.BimmerHeads.com
      • JGood
        • Jan 2004
        • 7959
        My HAWK HPS pads are a little noisy. Either way I'd check out tirerack.com, get OEM rotors (~$30 a pop), and whatever street pad you feel like trying. They have it broken up nicely into driving styles so you should be able to find what you like. Even if you don't order through them you can see what pads work best for what application. I don't have experience with cheap, non-performance pads so I can't help there. Actually, I did use PBR delux a long time ago on my eta, but I really don't remember what they were like, I was only 16 and didn't know shit, haha.
        e30 restoration and V8 swap
        24 Hours of Lemons e30 build
        • einstein57
          • Jun 2007
          • 10780
          there is a nice ebay set up with zimmerman x drilled rotor, ss brake lines, new pad sensors, axxis ceramic pads, and assembly grease thats not too expensive. They also have a non drilles set w/o lines. the worked pretty good but mine started squeaking yesterday after a long hard canyon run. I've had them on my car for about a 11 months.
          www.gecoils.com
