I regard of fitting 15" x 8" Rota wheels, it is possible to check fitment without even touching neither the wheels, nor the btakes. If someone can ask Rota for a pdf profile of their wheel, I can make you guys a mock-up to verify fit.
Just as the one for the e30 Race kit and Team Dynamic Pro Race 1.0
Be aware that the 1.2 version may require a 3mm spacer. Which I now supply in kits upon request. Racers using those wheels, will use a 12mm hubcentric spacer to widen their track anyway.
BTW I received to day the first rear race kit for e30s. 11.75" x 1.25" rotors and Superlite 4 pot calipers. I am sending them to the anodizing shop and they should be ready soon. Later on, I will produce the steel ring that allows to have the fully functional ebrake, not just a parking brake.
I now also have 14" x 1.25" (355mm x 32mm) front kits for e36 and e46s, as well as rear 12.2" x 1.25" rear kits for the same cars. Rear Z3 and M Coupe kits are available too. They basically use e36/e46 hats, and e30 caliper brackets. Another exclusivity.
