CAB recommendation
  • viali8
    • Nov 2005
    • 673
    CAB recommendation
    I am about to replace my CAB. I wanted to know what would be a nice upgrade. Keep in mind that i use my car as a daily driver and do not track/race. I am currently looking at these
    Shop BMW E30 bushings, mounts and performance parts for street, drift, track and race. Build with the best - Made in USA!
    parts 70A or 75D
    any recommendations
    For a purely street car there's no real reason not to use the OE bushings. but if you want to use the AKG bushings go with the softer of the two, which I think is the 70A units.
      • 34844
      get the OEM M3 offsets.
      • viali8
        • Nov 2005
        • 673
        i read that the OEM M3 bushings are only helpful at high speeds
        • kencopperwheat
          King of Kegstands
          • 14396
          The increased caster from the offset helps with highspeed stability. They're rubber and solid so they'll last and aren't as harsh as urethane.
          Originally posted by Gruelius
            • 34844
            it also helps at lower speeds like autox, because of the increased dynamic camber (your outside wheel gains camber as you turn sharper, because of caster).
            • viali8
              • Nov 2005
              • 673
              would you recommend the e30 m3 bushings over the AKG urethane for daily driving use?
              • atomic
                • Jun 2007
                • 5691
                You can also use e36 m3 CAB's as well. They are solid rubber and a cheap upgrade over oem CAB's.
                • 2002maniac
                  • 4260
                  Solid rubber offset.
                  • gearheadE30
                    • Jun 2007
                    • 3734
                    Only the '95 e36 m3 had offsets. I'd go with an offset either way because they are an upgrade for about the same price as stock. I have a set of AKG ones that I'm getting ready to install. The only thing about them is they don't have the little alignment arrow that the OE ones have.
                    Project M42 Turbo
