Strange brake issue-
  • TTe30m3
    • Aug 2007
    • 70
    The problem is when I gradually push on the pedal, it goes to the floor. But the more abrupt I push it, the more it 'catches'. I bled the brakes tonight. It made it a little better but not much. If I sit at a stop with the pedal pressed down, it eventually goes down to the floor. Any suggestions? Thanks!
  • smonkbmw
    Professor
    • Jun 2006
    • 4549
    sounds like the same issue with my eta. did the brake booster already, next is the master cylinder.
      • 37833
      Sounds like the master is bad.
      Grover Beach, California
      BimmerHeads.com
        Bad master cylinder or a leak at a caliper or line.
        • PiercedE30
          • Apr 2005
          • 4220
          Mc
          My 2.9L Build!
          • NC325iC
            • Mar 2004
            • 6565
            my car does that too, its always done that, most cars i drive do that, its not like they just fall to the floor if you lightly push on it but if you stop at a light or something while your waiting the pedal goes down some (i dont think it gets to the floor)
              • 37833
              That's not normal.
              BimmerHeads.com
              • rcko
                • Mar 2007
                • 295
                same issue on my old CRX... master cylinder is kaput!
                - 0.05s and 0.1s FTW!!!
                • golde30
                  • 11464
                  my car did this, it was a leak in the rear left brake line.
                  then it did it again, and it was the front right brake line.
                  then it did it again, and it was the rear brake line that goes above the subframe.
                  i hate Goodrich SS lines....
                  IG: @Baye30
                  • TTe30m3
                    • Aug 2007
                    • 70
                    Thanks guys.... looks like I'll do the MC soon. Its sooo annoying to drive. A fast car that doesn't stop!
                    • TTe30m3
                      • Aug 2007
                      • 70
                      Thanks for the help everyone. Put in a 750 MC and its great now.
