Hydraulic Ebrake?
  • Dominic49
    • Feb 2007
    • 1373
    Hydraulic Ebrake?
    the answer is YES!
    Input Line (10x1 Male to -3AN female fitting to [-3AN male fitting to 7/16-20 Banjo]) plugs in to the brake proportioning valve on the (US) drivers side of the car.
    routing of the lines.... i am going to have to route it again in this section my foot rubs against the line when i push on the throttle.... i will run it up higher then the pedal.
    view of the line going down the left side of the transmission tunnel
    I retained the stock handbrake incase I have to park on a hill
    shows the mounting in comparison to the stock handle
    above view showing relation of hydro to stock cable, also shows how close the handle is to the shifter when the shifter is in neutral
    routing of the rear line (10x1 Male to -3AN female fitting to [-3AN male fitting to 3/8-24 banjo])
    rear hose gets plugged into the rear distribution block
    be careful where you drill the tie downs..... (I got lucky right there >.<)
    SUCCESS!!!!!
    SUCCESS!!!!!
    MODIFYING YOUR BRAKING SYSTEM IS DANGEROUS AND ILLEGAL DO NOT ATTEMPT TO DO THIS ON ANY STREET VEHICLE!
    RACE/DRIFT CARS ONLY!!!!
  • BeirBrennerE30
    • 2740
    well played sir...
    e30sport.net
    '06 M3 Competition - 6-speed
    '97 Range Rover Vitesse
    • FLUTE007
      • 485
      was thinking of a new way to shave some lbs and this is a great idea, could help with some tight turning also. great job , clean too. thanks for the idea.
      one question how wil you bleed this with a power bleeder?
      • Dominic49
        • Feb 2007
        • 1373
        same as usual :D
        • shiboujin
          • Feb 2006
          • 2791
          can you email me the forum post or post it on my boards? e30drifter.com :)
          • e30 gangsta
            • 3877
            question thats a k sport ebrake right? If so why did you keep the stock ebrake it has a locking mechanism for parking i believe.
            • Dominic49
              • Feb 2007
              • 1373
              i'm fearful of the quality of the locking mechanism....
              aluminum fatigues over time and everytime it locks it has a good 40lbs or so of force being put onthat liettle .25inch square of aluminum...
              • BeirBrennerE30
                • 2740
                I didnt realize that ebrakes liek that could be bought.... anyone have a link to some specs
                e30sport.net
                • Mr.sexymorningvoice
                  • Sep 2007
                  • 402
                  nice setup..whats the possibilities of us finding out some more info on it?
                  • Dominic49
                    • Feb 2007
                    • 1373
                    EAR-640303ERL -3 ST. MALE STEEL 10MM X1 CONV x2
                    EAR-600103ERL -3 ST. STEEL HOSE END x2
                    EAR-620003ERL 20 FT. -3 SPEED-FLEX x1
                    EAR-977503ERL 3/8 BANJO BOLT x1
                    EAR-977504ERL 7/16 BANJO BOLT x1
                    EAR-981503ERL -3 UNION x1
                    EAR-997603ERL BANJO -3 TO 3/8 x1
                    EAR-997634ERL BANJO -3 TO 7/16 x1
                    • metal_til_deth
                      • 30
                      Really nice but can I ask you how much does it cost for everything?
                      • Dominic49
                        • Feb 2007
                        • 1373
                        ~300 after everything
                        100 lines and fittings from summit
                        150 for ksport
                        15 nylon tiedowns and screws/grommets
                        • BeirBrennerE30
                          • 2740
                          their website isnt very informative... how does it lock? can you use it as a normal ebrake and a drift style ebrake?
                          e30sport.net
                          • metal_til_deth
                            • 30
                            Do you need a new master?
                            • AndrewBird
                              The Mad Scientist
                              • 11898
                              So is the purpose purely for drifting?
