Hydraulic Ebrake?
  • var1ant
    • Apr 2005
    • 509
    Originally posted by NitroRustlerDriver
    So is the purpose purely for drifting?
    You could use this type of handbrake for rallying too. Road racing not so much.
    '87 alpine white 325is
    • shiboujin
      • Feb 2006
      • 2791
      Yep!
      Well, You could use it for doing the starting burn out if youre FF and drag race. That way you dont use up the front brakes.
      • Dominic49
        • Feb 2007
        • 1373
        hmmmmmmmmmmmmmmmmmmmmmmmmmmmmm tested it out at the drift event yesturday and was less than impressed... i'm going to try swapping for stickier rear pads and let you know how it goes...
        • Massive Lee
          • Sep 2006
          • 6785
          If I were you, I would put the brake lever upright, in a push layout. You'll get better ergonomy and strength. Your feet push pedals, right?
          massivebrakes.com
          • Dominic49
            • Feb 2007
            • 1373
            i'm working on a solution to that. I have to fab up some sort of bracket to hold it because as of right now there is no room for mounting it as said. I need to get rid of the AC and heater core and mount it under the dash
            • 92 mtechnic cabrio
              • 4907
              Originally posted by Dominic49
              hmmmmmmmmmmmmmmmmmmmmmmmmmmmmm tested it out at the drift event yesturday and was less than impressed... i'm going to try swapping for sticker rear pads and let you know how it goes...
              you mean replace the drum shoes? :-?
              R.I.P 07/01/09 - 04/23/10 :(
              • Dominic49
                • Feb 2007
                • 1373
                this ebrake setup uses the rear calipers
                not the rear drums
                • Garageaholic
                  Freestyle Fabricator
                  • Dec 2005
                  • 5204
                  Very, very nice addition to the forum.
                  Recent Rebranding!!
                  E30 SM62/S62
                  E30 M60 V8
                  E30 M30 Big 6!
                  Instagram.com/garageaholic
                  Youtube.com/garageaholic
                  • Massive Lee
                    • Sep 2006
                    • 6785
                    Hi Dominic.
                    You may want to install the lever at the same level as the steering wheel. Being in a push layout, you can apply much more pressure on it as your shoulders will be backed by the seat back. You may even want to modify the lever's shape to bring the handle closer to you.
                    Don't hesitate to post pictures when you have new developments.
                    massivebrakes.com
                      • 4907
                      not the rear drums
                      Oh....well that sucks
                      • Dominic49
                        • Feb 2007
                        • 1373
                        Hi Dominic.
                        thats one of the nice things about the ksport the actual handle part bolts to the lever so i can fab up a longer angled handle to put the lever where i need it.
                        i am going to need to remove my heatercore/AC unit in order to put it where i want it (under the dash with handle right next to steering wheel)
                        • Mike B.
                          • Jan 2006
                          • 987
                          How about a tall handle like this:
                          • Dominic49
                            • Feb 2007
                            • 1373
                            thats the cnc setup. i might end up picking one of those up if i cant get this ksport worked out :\
                              • 4907
                              I wonder if there are any solutions similar to this for rear drum application
                              I asked my buddy today and the shop's car's hydraulic e-brake is also to the calipers, this whole time I thought they went to the drums (since they went through the trouble of doing Z32 rear hubs conversion)
                              • Dominic49
                                • Feb 2007
                                • 1373
                                youd have to fab up a whole hydraulic setup for the rear drums?
