More control arm help
  • Spencer
    • 767
    What did you use to get the bushing off of the control arm?
    Also, bentley says you need "BMW special paste" - What is this stuff>?
    Spencer
  • rs4pro3
    • 5808
    I used a 3 jaw puller. For the paste, afte the bushing is pressed into the bracket soak the bracket in bushing in HOT Very soapy watter for a good bit. The slabon dishwashing soap onto the control arm, grab the bushing out of the watter and push very hard very quickly and it will slid right on. Don't let up but just keep pushing untill it slides.
    85 325e 2.7 ITB'd stroker
    • James Crivellone
      Head Janitor
      • 6305
      yeah just yank em off as said above
      now to install it you obviously need to press teh bushings into the carriers.
      in terms of putting the control arm bushing on the control arm, if its the rubber one it will take a little effort and perhaps a press to get it on there, if they are Urathane then it will just slid on with no effort
        • 34844
        to get the old bushings off the control arm you can soften them with a torch. heat them up until they catch on fire, blow out the flames and pull them off, it's pretty easy. when you put your new ones back on, make sure your water is VERY soapy and hot, and soak the bushings in the water for a while. make sure you put the car back on the ground before the soap disolves so the bushings can properly settle, and don't drive it for a few hours until they are set.
        • Spencer
          • 767
          I tried using heat to get it off - didn't work.
          The bushing wouldn't move.
          thanks for the info.
          I didn't know about Urathane ones :?
          Spencer
            • 34844
            You didn't get it hot enough then.. like I said, it's hot enough when it catches on fire. like this:
            :twisted:
            • e30evolution
              West Werks
              • 1888
              dont light your car on fire... use a press and do it right
              or if on the car... use a puller
              http://www.westwerksauto.com
              • E30//MAN
                • Mar 2004
                • 98
                I used a power saw and cut through the rubber, and through the inner metal ring.
                Ha ha. I love the pic.
                WTB m50 or s50 swap parts, PM me
                I call her Jenny, pics coming soon.
                Now with Eibach springs and bilstein sport shocks
                  • 34844
                  why, when you can pull it off by hand? it's not like damaging the old bushing is going to hurt anything. ;)
                  • Spencer
                    • 767
                    The control arm is off the car becuase I'm just adding new ball joints and bushing to an old one and then i'll swap it over.
                    I heated it for a good five minutes.
                    Couldn't get it.
                    I'll have to try harder later.
                    Spencer
                    • cheezewiz
                      • Jan 2004
                      • 65
                      getting the bushing on the control arm
                      me and my dad did the control arms and bushings, after managing toget it all of, we got the bushings pressed into the carriers at a shop. We got come and couldent get the bushing on, so my dad bolted the carrier on backwards to the car, jacked the car up, lubed the bushing, and put the control arm under it. Then let down the car slowly and the arm pushed right into the bushing ;). lol we all thought my dad was completely nuts.
                      • James Crivellone
                        Head Janitor
                        • 6305
                        Re: getting the bushing on the control arm
                        I still cannot beileve that worked, it was painful to watch :p
                        • 65Matt
                          • 172
                          Cut the old bushings out with a sawzall. See links below:
                          I didn't have my bushings pressed in, but I did have to buy the biggest vise home depot sells. It pressed the new bushings in easily and a wimpy vise will not cut it!!
                          To install the bushing/bracket assembly onto the arm, I just used a big socket and a hammer. Very easy this way!!!!
                          • e30evolution
                            West Werks
                            • 1888
                            do not use a hammer to hit the control arm
                            then end of the control arm wil musrom over and the new bushing will not fit on
                            use a press
                            • 65Matt
                              • 172
                              Not sure if that was directed at me, but to clarify, you hit the bushing, not the CA. the socket and the bushing slide right over the end of the control arm.
