How to bench bleed a master cylinder?
  • JGood
    • Jan 2004
    • 7959
    I picked up a new master cylinder, and will be installing it this weekend. I've never actually bench bled a master cylinder, so I'm not sure how to do it. I did a Google search and most sites said the MC will either come with a "bench bleeding kit", and if not, I should buy one.
    So whats are your tips, tricks, and techniques?
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
  • Teaguer
    • Sep 2004
    • 6167
    You can mount the reservoir on it and then loop rubber hoses from the outputs back into the reservoir .
    Then pump the piston a few times until no more air comes out of the lines .
    Thats pretty much it , you just want to fill the inside of the MC with fluid before you mount up the lines and have a bunch of air pumping through the system .
    • 2002maniac
      • 4260
      I'm with stupid^^
      I have two ends of a hard line that I fit into the output ports of the MC, then use two pieces of rubber hose hose clamped to the hardline.
      • JGood
        • Jan 2004
        • 7959
        OK, 2 questions:
        Where did you find a tube that fits perfectly in the outputs, that doesn't leak?
        When you pull the tube to thread in the brake line, doesn't that create an air bubble? Air rises, so wouldn't the air in the line work it's way up into the MC?
        • JGood
          • Jan 2004
          • 7959
          Originally posted by 2002maniac
          I'm with stupid^^
          Cool, I have a parts car I'll cut the fitting and part of the lines off of.
          • TopOfTheLine89
            • Jun 2007
            • 919
            most places include plastic hardware to block off the holes or bleed them to the reservoir, i guess yours didn't though.
            97 tacoma 5 spd 4 cylinder
            2001 330ci 5 speed
            83 733i 5 speed, (FS)
            • JGood
              • Jan 2004
              • 7959
              Nope. Not a big deal though, as I've already found a solution for that. Just trying to figure out how to keep it air free while removing them and installing the lines...
              • JGood
                • Jan 2004
                • 7959
                anyone?
                • e30_kid89
                  • Apr 2006
                  • 489
                  I'm supposed to be able to help you, seeing that i just bench bled a MC 2 days ago in class, but i forget now making me useless.:(
                  • Mike B.
                    • Jan 2006
                    • 987
                    Don't worry about it. The amount of air that may infiltrate when you remove the lines will be easily removed when you bleed the lines/calipers.
                    • bwanac
                      • 3354
                      Put on the reservoir of fluid, and cover the holes with your fingers and plunge it back and forth a few times.
                      • JGood
                        • Jan 2004
                        • 7959
                        what?
                        Anyway, got it done. It was actually really easy. I put a 25mm in, as it was cheaper then stock. What a difference over the old busted piece of shit!
                        Thanks guys.
                        • MIKe30
                          • Sep 2006
                          • 2334
                          does this work?
                          edit: update - made my own. Got 2 bleeder screws that fit the master cylinder at the local parts store, vinyl hose from home depot. screwed in the screws, attached the hoses and looped them up into the resevoir. Pumped the brake pedal a few times and it began to circulate.
                          I also used a pump to remove the dirty fluid that was initially pumped out. Did that a couple times too, made sure it was nice new fluid throughout. Easy enough.
