My caster is out of spec?
  • Turf1600
    • 9815
    So, my car is aligned perfectly. .17 toe in on each wheel. However, I'm pulling left. My caster is out of spec as well. I'm running all new shocks, springs, control arms, tie rods, and derlin CABs. Will improperly pressed offset cabs impact my caster? Also, will caster cause my pull?
    Thanks-
  • fretburnr
    • Jan 2005
    • 1496
    if one of your CABs is rotated in the mount and not at the proper upright position, the offset would definitely affect your caster as well as camber. I don't know if caster can cause pull while driving straight, but different camber certainly can - it's called camber thrust.
    Jay
    • houstonh
      • Aug 2007
      • 293
      so your drivers side has less caster correct? What springs/upper mounts are you using? How was it before the install of said parts?
      • Turf1600
        • 9815
        New bilstein sports
        eibach springs
        It pulled right before - but due to terrible alignment.
          • 34827
          Thanks-
          yes, and yes.
          • Turf1600
            • 9815
            Maybe I'll just pick up some THR cabs.
            • Madhatter
              • Oct 2004
              • 966
              have you got the original items to return it to stock? id probably try replacing the cabs first and getting an alignment to check it still isnt out, before spending money on some aftermarket items. You could have something bent/damaged that is causing the caster issues, might end up buying the treehouse ones and find its still out.
              Just a little project im working on
              - http://www.lse30.com -
