Spherical trailing arm bearings
  • Jean
    • 18228
    How many of you tried these?
    I plan on installing poly or delrin in the subframe as there is no multi-axis movement there, and thinking about running spherical in the trailing arm to subframe to allow for multi-axis movement and no bind etc...
    Thanks!
  • Sam Cogley
    • Jun 2008
    • 521
    Haven't tried them on a BMW, but my '77 Vette has them in back. I haven't noticed anything too harsh or weird from them, but it doesn't have much driving time since the suspension was finished.
    • erik325i
      • Jan 2005
      • 3567
      Thanks!
      Jonathan on baye30 did it on his M3.
      Erik
      • Jean
        • 18228
        Thanks, i'll pm him!
          • 34827
          I hope this is for a track car, because generally they will wear out a lot faster on the street.
          who sells bearings like that for the E30 btw? compatible with weld in TAB adjusters?
          • Jean
            • 18228
            It's for my 89 24v car, it's a track (hpde) and solo2 car only. TC has done it on someone's car but I haven't found anything yet that I can order..
            • var1ant
              • Apr 2005
              • 509
              If you want to do this you'll probably want to copy the setup the e30 m3 group A cars had going for them. There were pics of the setup on e30m3performance.com but the site appears to be broken.
              '87 alpine white 325is
              • PiercedE30
                • Apr 2005
                • 4220
                There is actually a thread about this over on BF.c under the track section.
                My 2.9L Build!
                • erik325i
                  • Jan 2005
                  • 3567
                  link?
