Worst DIYer EVAR!!
  • ldsbeaker
    • Aug 2004
    • 3098
    Worst DIYer EVAR!!
    Yup, that's me. I'm trying to pull my rear wheel bearings with the B90 tool, and I feel like a tool myself, as it isn't working! About all I've managed to do is bend the shit out of the brake dust shield. I'm using an old e-brake shoe, and the horseshoe as spacers. It's just not freaking coming! Help!
    Slicktop City!
  • ldsbeaker
    • Aug 2004
    • 3098
    No one? Everyone hacks the shit?
    Slicktop City!
    • 2002maniac
      • 4260
      Sometimes the rear bearing is tighter than others. You just really have to wail on it. good luck! Shop press is by far the best way to do it if you want to remove the entire T/A.
      • Rolla1990
        • 199
        There's a tool out there somewhere that I borrowed from my buddy once... I think it was called the "Hub Shark". Worked awesome.
        Turbo M20, MSnS, 38lb, 3" no cat, RPI 12.2", ATS DTC, 240whp/240wtq, Lmnop. www.DonsGarage.net
        • NJGreenBudd
          • Aug 2009
          • 121
          Just drive it out from the inside using a large socket and 4lb hammer. It my take a bit of work but it will come out.I just did mine this week and they both came out fine, you'll need to remove the inner race from the hub most likely. I put my new bearing in the freezer for an hour and greased the trailing arm hole, used a piece of 2x4 and hammer to install new bearing. Used the old bearing to fully seat new bearing. Don't forgot to install the circlip before pressing the hub back in.
          '87 325e
