RTAB and grease
  • chip
    • Jun 2008
    • 130
    RTAB and grease
    When installing RTAB's (AKG), what surface(s) would you apply some grease to eliminate squeaks? Would you also apply grease to the subframe bushing?
    TIA
    Chip
    '87 325iS
    spece30
    '01 330 5sp
    '10 328 6sp
  • E30_fiend
    • Apr 2006
    • 7348
    apply it to EVERYTHING. On the sleeve inside the bushing, the hole for the sleeve inside the bushing, the outside of the bushing an of course the holes in the trailing arms where the bushings go.
    DO NOT BE SPARING WITH THE GREASE. If you can get a hold of some, get some copper based grease. It lasts a lot longer. You cant have too much grease. If you are sparing with it then you will have squeaks in no time.
    Good luck
    Taylor
    • DCColegrove
      • 2748
      There is a special silicone based lubricant for these...
      I think (but I'm not sure) AKG supplies it with their stuff.
      • Optimator
        • 1396
        I had AKG bushings on my old car. The bushings did not come with grease. I used Molykote 44, a silicone grease.
        -OVULATOR (as named by jflip2002)
        Past Cars: Schwarz 1990 325i-2 (crashed), Calypsorot 1991 325i-2 Sport (rear ended)
        Now: Blake-stitched mediocrity :(
        • gearheadE30
          • Jun 2007
          • 3734
          I also have AKG bushings; used marine grease. So far, so good about a year into it.
          Project M42 Turbo
          • backtrail69
            • Jul 2005
            • 4471
            I use sil-glide for all my urethane.
            :: PNW Crew ::
            '87 325 4dr, '74 2002
