I have these TA bushings from Bavauto Part # : 33 32 9 058 822
What I know about them is they are not adjustable but can be set to desired camber when installed. But I don't know what number to set it at. If the inside is at 12 o'clock and the outside is at 6 o'clock then that is the least camber and vise versa. When I called Bavauto that is all they knew. So Should I install them at 3 and 9 o'clock to get the middle of the camber adjustment since they don't have any degrees only 6-12o'clock??
