Ok so this might be the wrong section and if so please relocate this to the proper section. The 325e E30 that i am looking at has what appears to be a cracked radiator support bar, the one that runs under the radiator. The bumper is cracked, and the hood latches are bent. You have to muscle the hood to get it to close but once secured it stays closed. Wondering how important that front section is to the chassis? Looking for help.... thanks
Bent Frame?
if its just hte radiator support, you should be able to get another one and just have a body shop cut and weld it back on. -
Always disconnect the battery before doing any electrical welding on the car. And position the ground clamp close to where you'll be welding. If you do that you won't harm the electronics.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
