No surprise here: 16x8 et20 Rota Slipstreams clear the 300x32 Superlite floating race kit with room to spare.
Massive BBK Wheel Fitment Guide
Very nice^ I'll be running Alpina Kopis 17" Et 35 with a 25mm spacer, should be able to clear.Comment
Another wheel that fits: Kosei K4R 16x7.5 with a 15mm spacer. Clears the strut with about 6mm to spare, tons of brake clearance. I would check the 15x8 K4R, but they are backordered through June.
Pics are here: https://picasaweb.google.com/1059796...eat=directlink
1973 BavariaComment
TRM 15x8 (again)
I just printed off the fitment template for the 300x22mm Sport Kit, and fit it up against my new TRM 15x8s.
Looks like if I run about a 3mm spacer, the only thing that hits is the head of the guide bolt/retaining pin that holds the pads in. And it looks REALLY close. That's about all the spacer I think I can run, without rubbing on the outer fender. I might be able to fit up to 10mm, if I run a ton of negative camber all the time (which isn't so bad).
Has anyone else run into this? Is there a bolt with a thinner head that solves the problem?
Also, this template only shows one plane of fitment - I have read that the caliper is too long to fit under these wheels as well, and needs grinding - is that indeed the case?Current:
1991 325i Sedan - S50 Swap
1988 325i Cabrio
Past:
1991 M3
1991 318is
1985 325eComment
I am noob at BBK (plus I am new to BBK) I am going to be installing my BBK and will need new rims and tires. I was hoping that 15 x 8 +25 would be able to fit 280mm kit. Here is a link to the rim I was looking at.
Check the fitment template against the wheel
Also, Massive no longer sells any Wilwood component. All kits using Wilwood calipers and rotors will be sold as installation kits until inventory dries out. Buyers will get the Wilwood calipers and discs from their usual source. All Massive kits will use AP Racing calipers.
massivebrakes.com
I don't understand why you mention the RX7 caliper.Brake harder. Go faster. No shit.
massivebrakes.com
massivebrakes.com
