Massive BBK Wheel Fitment Guide
  • robgoesvroom
    • 821
    #271
    why go 8" when you can go 10" ;)
    Originally posted by JRKOUPE
    as Lee said..
    those are gorgeous......
    always always loved them. very proper, not ricey......
    just wish they did a 57.1, 8 inch...et 20
    • TheDirtyS54Thirty
      • Dec 2016
      • 88
      #272
      My dawg! Are you running a BBK? Hows the clearance inside the wheels?
      E30 S54
      • robgoesvroom
        • 821
        #273
        No not running BBK yet, all stock brakes. Been eyeing these MASSIVE kits for a long time but haven't pulled the trigger
        • Massive Lee
          • Sep 2006
          • 6785
          #274
          Wondering if anyone has a Sport or Race kit fitted on these Jongbloed wheels. Maybe even on 15x8. It seems they are available in direct fit - 57.1mm hub and et15 or et25
          JRW Spec E30 wheels - 15x7 4x100 57.1 - ET15 - Satin Black - Gloss Silver - Gloss Anthracite - set of 4 $400 with Free Shipping
          massivebrakes.com
          • Mfever
            • May 2007
            • 1058
            #275
            What is the largest kit that fits under Euroweaves? And do the kits still come with ap racing calipers?
            • Massive Lee
              • Sep 2006
              • 6785
              #276
              Count yourself lucky if you ca fit something else than stock calipers under these wheels.
              As far as I know, the 280x22mm Street kit will fit. That's it. The VW Corrado rotor is offset more inward than the e30 rotor, and the caliper is narrow.
              Available in two configurations. VW Corrado G60 rotors, or two-piece rotors with alu hats
              What else is available for our e30?
              The kit with an AP Racing caliper is a 300x32mm kit. No way it fits under your wheels. and it is very expensive as calipers only will cost you $1200.00usd for the set ;-)
              massivebrakes.com
              • Mfever
                • May 2007
                • 1058
                #277
                ahhh rats! I think the street kit would be sufficient for the auto crossing that I do... I would love the ap racing calipers over the wilwoods though. Oh well! Thanks for the quick reply!
                • Q8y_drifter
                  • Aug 2009
                  • 297
                  #278
                  If anyone is wondering
                  XXR 531 - 16x8 ET20 require a minimum 10mm spacer (12mm would be a safer option) using the Massive BBK 300x32mm Race Kit. No issues in the rear.
                  Alpine White 1989 E30 Coupe - LS1/T56
                  • Massive Lee
                    • Sep 2006
                    • 6785
                    #279
                    Good to know. Now we want to see pictures ;-)
                    massivebrakes.com
                    • Massive Lee
                      • Sep 2006
                      • 6785
                      #280
                      For autocrossing, you don't need more than the Street kit. It will be a great improvement over stock. Less play in the caliper. Better modulation and cheap brake pads.
                      massivebrakes.com
                      • Mfever
                        • May 2007
                        • 1058
                        #281
                        Do they even make a AP racing caliper in the street kit size? or are they unobtainable?
                        • Massive Lee
                          • Sep 2006
                          • 6785
                          #282
                          Only within the 300x32 Race configuration. At $600.00usd a pop, you want to put these clampers to a good use. ;-)
                          BTW $600.00usd is what the AP Racing importer Essex, in North Carolina, charges. You can probably get them for cheaper from a distributor. These calipers were much cheaper initially, then suddenly the price hit the roof...
                          If anyone was able to get them for cheaper, let us know. ;-)
                          massivebrakes.com
                          • Mfever
                            • May 2007
                            • 1058
                            #283
                            Copy that! thanks for the quick responses Lee as well as the awesome products!
                            • TheDirtyS54Thirty
                              • Dec 2016
                              • 88
                              #284
                              Originally posted by Northern
                              I did some skimming of the thread, but before I buy new slalom wheels, does the TRM C1 15x8 (or any of the kosei 15x8 et20 tirerack wheels) fit with the 300x32 + Superlites "Race" kit?
                              Also interested in this.
                              E30 S54
                              • bnmueller
                                • Aug 2015
                                • 16
                                #285
                                What about the Concave 17x8.5 ARC-8?
