Brake light warning always on
  • Iloveboost
    • Sep 2019
    • 136
    Hi
    I just got a little annoying problème with my parking brake light on the instruments cluster .
    it is always on when the car running or key at ON position .
    The 3 brake light in the rear are working perfectly.
    the switch on the ebrake working good too .
    the parking brake light won’t go off .
    When I pull the ebrake lever the light comme more a little more bright and when the ebrake is off the light go less bright but still kind a bright ( very enough to see it in plain sunny day)
    inhave checked everything fuse , they’re good .
    check the voltage at the fuse , it is OK
    didnt check the brake switch because i assume it works good ( have rear brake light working perfectly.
    anyone can help me ?!
    thanks !
  • Garemie
    • Dec 2018
    • 107
    Brake fluid level related? If so you likely have a leak and need to address it.
    • Iloveboost
      • Sep 2019
      • 136
      Brake fluid level is good .
      no leak at all..
      • Garemie
        • Dec 2018
        • 107
        Test the brake fluid float switch. I'd almost bet that's it.
        • Iloveboost
          • Sep 2019
          • 136
          I have unplugged it and the light was still ON .
          i am starting to think that maybe the wire who goes to the hand brake switch may be grounded somewhere on its route ..
          • Garemie
            • Dec 2018
            • 107
            You have to close the circuit. Unplugging it is the same thing as it being low enough to trigger.
            • Iloveboost
              • Sep 2019
              • 136
              Did I can put a wire on the conector from one pin to the other to « close » the circuit ?
              • Garemie
                • Dec 2018
                • 107
                Temporarily yes. Will send the same signal as a full reservoir.
                • cheffy30
                  • Sep 2016
                  • 1159
                  clean and check socket connections to all the related bulbs? sent from hell using tapatalk
                  '90 325i sedan daily driven
                  '85 325e coupe also a daily
                  • Iloveboost
                    • Sep 2019
                    • 136
                    I doubt it can Be an socket connection issus since the bulb is lightening.. an issue there will be much not light the bulb ?
                    i have jump the conector and the the light does not came of ..
                    more more suspecting the wire signal for the handbrake must be grounded ...
                    this winter I have remove my seat and carpet to weld the floor. Maybe the signal wire is grounding on the chassis ...
