Need some advice with my brakes setup.
  • 540ig5
    • Nov 2013
    • 20
    Need some advice with my brakes setup. I’m currently running stock e30 rotors and calipers with a 944 booster and an e32 master cylinder. I love the stiff feel of the pedal and the car stops just fine. However, the force required to come close to locking the wheels is beyond what I can produce. And even if I could press that hard on the pedal, it feels like that would bend the pedal. I’m thinking of getting the wilwood bbk. What do you guys think? Is this a good way to keep the pedal feel, yet reduce the force it takes to max the brakes out?
  • AngeloF10
    • Dec 2015
    • 191
    Following. In addition to your question and maybe helpful to you too, is there a wheel offset difference needed for the Willwoods. I know there is a diameter recommendation of 15”. Sent from my iPhone using Tapatalk
    • twright
      • 707
      Change the brake booster to one from a BMW X3. It will reduce your pedal pressure significantly.
      Go to the M50/M52 swap section. There is plenty of info there on how people have done it. Those people have done it because there is not enough room for an E30 brake booster.
      Even without an engine swap, its a good upgrade.
