Caliper Piston Sizes/Compatibility
  • Nate37
    • Sep 2019
    • 80
    I took apart the brakes on my 318is to rebuild the calipers and get the calipers sandblasted and re-plated. Unfortunately the sandblasting shop lost my pistons, so now I have beautiful caliper housings with nothing to put in them. I did a bit of searching on this, but nothing turned up: are the caliper piston sizes the same across all the E30 disc brakes? This page made it sound like the rears are interchangeable, but in the front it may matter whether the caliper was made by Girling or ATE: https://www.e30zone.net/e30wiki/inde...rakes#Calipers My car has Girling calipers in the front. Does anyone know for sure if they are the same?
    Basically, I'm wondering if these will fit, even though they say they are for ATE calipers and do not list the 318is as a compatible model:
    High-quality steel pistons for your Ate brake caliper rebuild. The last set of caliper pistons you'll ever need!
    If neither of those will work, where else can I source them? Hoping to buy just the pistons without having to go buy 4 whole calipers from a scrap yard...
  • Vincenze
    • Apr 2019
    • 1031
    The rear brakes are all ATE.
    There are remanufactured Girling brake calipers on eBay, etc for $40.
    • fitswell
      • Nov 2008
      • 224
      the issue with reman calipers is that they will arrive without the protective zinc coating, especially if you go for the budget version. they will rust up and look like poo in no time at all.
      01.5 S4 Avant - Sold
      88 325iS - In pieces
      91 e34 - Totaled by some dumbass
      90 325i - Daily
      06 e91 - Sold
      feedback thread
      • Nate37
        • Sep 2019
        • 80
        Thanks guys. Been meaning to write this up in my build thread, but I ended up sourcing new pistons on eBay and using my old calipers. I bought them from Frentech UK - would highly recommend if anyone ever needs new pistons. They were very responsive and even created a new item on their eBay store with only the parts I needed to order. Here's their store: https://www.ebay.com/usr/frentech-uk...p2047675.l2559
