In the midst of a steering rack swap on my airbag model car (amongst other things). Trying to remove the 32mm steering column nut to separate the column in order to remove the plate so cut the wall / install my new plate, but this steering column nut will NOT budge.
any tips before I smash my arm again? My steering wheel is still on with the wheel locked, is the amount of pressure I’m applying against the lock okay? Should I be countering the pressure in some way?
For reference I am using a 15” adjustable, and it will not budge a bit. Thanks.
