so i was talking to a friend of mine the same friend that said taking the cats off would fuck up my car lol but yeah he was telling me that honda civic coilovers would fit on a e30 this would be great seeing how ground controls are so expensive and honda civic coilovers are farly cheap depending on were you look is this true?
honda coilovers on a E30
no it's not. springs are springs. yes, some are higher quality than others. if you can find decent quality springs that are the right height, width, and spring rate cheaper than something made for an e30, theres no reason not to buy them. same deal goes with perches, and even shocks for that matter. lots of the coilover guys use shocks from different cars when they shorten their struts.Comment
^You should shut the fuck up, stop posting and actually read something.
farnorthracing.com, that should keep you quiet on suspension opinions for awhile.
Tien's are fucking garbage. And a true coilover does fit in the back and many places make them.
Canadians shouldn't be allowed to post either.Need parts now? Need them cheap? steve@blunttech.com
www.gutenparts.com
Why are people so cheap when suspension basically holds your life in its hand?Comment
The brand of springs nor the valving of the strut/shock matter?
I supposed you don't know the difference between an Eibach ERS and Hypercoil spring vs a cheap knock off?
That they actually ARE the spring rate they claim to be and are consistent spring to spring. But I guess I can see how that doesn't matter. Or that struts/shocks of the same brand/model don't always have consistent damping damper-to-damper, even the expensive hand built stuff.
Go read the link I provided and come back when you have an informed opinion.Need parts now? Need them cheap? steve@blunttech.com
www.gutenparts.com
i never said any of that. i dont recommend knockoff springs or crappy ebay honda springs either. all i'm saying is that good quality suspension part of the right specifications will work whether or not they're made with the e30 in mind. if said parts are inexpensive, hooray.The brand of springs nor the valving of the strut/shock matter?
+1Comment
