airbag excessive play in steering.
  • chasiubao
    • Mar 2006
    • 335
    anyone have experience with excessive play with an airbag car? I think it has to do with the knuckle design. Previous owner said he replaced all steering related items control arm, bushings, tie rods etc. I'd like to just swap the knuckles from a non air bag in....let me know your collective thoughts.
  • gearheadE30
    • Jun 2007
    • 3734
    the only thing that is really different about the airbag cars is the column and a little flex disk. I think the u-joint is the same. the disk can't have any play in it unless it is broken, but that would be a bit obvious. Also, there is a nut on the steering column that you have to remove the knee bolster to get to, on the inside of the car. It can cause a steering thump if it isn't tight enough.
    Honestly, though, I'd say its probly worn tie rods or worn control arm bushings.
    Project M42 Turbo
    • ian e30 318is
      • Mar 2007
      • 1809
      I've had a small clunk noise when moving the steering wheel back and forth but i just replaced the tie rods and i took off the bolster off and made sure the nut was tight, so i know it isn't one of those. The only other thing that makes sense is the u-joint. anyone have any ideas?
      edit: could it possibly be that i need a new steering rack?
      1991 LS1 Swapped 318is
      Instagram:
      https://instagram.com/saltybeast/
      LS Build Thread:
      https://www.r3vlimited.com/board/for...s-e30-ls1-swap
      • Knockenwelle
        • Jul 2008
        • 395
        The airbag column is a notorious piece of shit. There's no real bearing support at the bottom of the column, only a bunch of tiny plastic pieces and bushings which all wear out. You could order all that new and tighten it up to factory spec, or rip it out and use a much better non-airbag column. Search for swap details.
        Mike
        '91 325i track car. Mostly...
