Bilstein Touring - Strut Question...
  • aworthybrother
    • May 2007
    • 899
    I read somewhere that the oil from the strut housing must be drained if strut is being replaced with BILSTEIN SPORT. My question is, do I still have to drain the oil if I am replacing the stock BOGE strut with BILSTEIN TOURING STRUT?
    Thanks in advance.
  • JGood
    • Jan 2004
    • 7959
    Thanks in advance.
    Bilstein tourings are twin-tube like stock, and have firmer valving then stock (more heat build-up) so I'd say you should have oil in there, just like stock.
    The only reason Sports/HD's don't require oil to reduce heat is because they are an inverted mono tube design. The piston is actually within the part of the strut insert that is up near the mount, which is outside of the strut housing.
    So in the below pic, looking at the two strut inserts on the left, the shiny metal tube outside of the yellow tube, normally covered by the blue boot, is what contains the gas, oil, and pistons.
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
    • tim88325is
      • Jul 2008
      • 201
      JGood, I am sorry, "yes" to draining/removing the oil or replacing/adding new oil for Tourings?
      I am actually doing this exact same swap this afternoon and was going to check with the BMW shop where I get the parts...
      Aworthybrother, the cardinal seats are looking good!!!
      • JGood
        • Jan 2004
        • 7959
        I meant since the Bilstein Touring strut insert is identical in design to the stock insert, it should have the same install procedure as stock. If stock requires oil, you should probably put oil in. The only reason they say to drain it for sports is because it's a completely different design.
        • aworthybrother
          • May 2007
          • 899
          Oh, thanks for clarifying. Thought you were saying "Yes" to drain the oil.. I was ready to drain it this weekend :p. I got confused with replies from other forums as well.
          • JGood
            • Jan 2004
            • 7959
            http://forums.bimmerforums.com/forum...+touring+class
            Yeah I dicked that post up pretty good. I'll edit it.
            • tim88325is
              • Jul 2008
              • 201
              Just to further clarify the final answer, my BMW parts guy said "no oil"...
              • aworthybrother
                • May 2007
                • 899
                As per the link I posted above from bimmerforums, the guy who called bav auto said the same thing - No Oil.
                another similar discussion that says No Oil.
