Hey IsItElectric?...my GC plates
    Wow, I've had mine for over a full season as well and had no such problems. I remember the top bolts don't need to be torqued down much at all, since the bottom plate is pressed into the upper plate.
      Originally posted by IsItElectric? View Post
      Per the Bentley manual, the recommended torque for the nuts to unite the strut tower to the bearing-plate are 16 ft-lbs. Being that the GC bolts are of similar size, I would use that as a guide.
      Yep, right.
      Hellabad's answer to me via PM:
      "Torque spec for all the bolts/nuts are the same as the stock upper mount nuts, which is 16-18 lb/ft."
      89 325is track project / 05 x5 / 99 M3
      E30 stuff for sale | Parts I'm looking for
        Yes, I have learned from this experience that I did overtorque them. My bad.
        But I've also learned that those socket head cap screws you're showing in your picture CAN put a much higher point load on the aluminum, and make it much easier to overtorque because you can use a larger tool to torque them down (vs. the button head cap screws that come with the kit).
        That being said, I am now (still) using socked head cap screws on the non-recessed slot (front of car) with BIG hardened thick washers to ensure the point loading is spread out more. I am using the GC-supplied button head cap screws on the recessed slot so I can get more positive camber to drive to-from events.
        Right or wrong, that's what I did this past weekend and it worked well. I only used allen wrenches to torque them down and was gentle with them at most.
        John
        1990 BMW 325i
          Do the steel ones have a steep price difference? I'm scared that someone is going to align my car and torque the hell out of them.
            no worries with GC kit, been running them for for 3 seasons with zero issues. i'll be buying the spec e30 plates from them when i swap out my suspension for spec e30 over the winter. i'm gonna miss this setup!!
            '12 F30 328i Sport Line
            '91 SpecE30 #523
            '00 Ford F-350 Dually Tow Vehicle
            BMWCCA #360858 NASA #
            128290
