Bilstein sports with stock 325is springs
  • e30_lover_CT
    • 182
    Anyone ever put this combo on their car? If so, how did it ride? I can't decide if I should transplant my H&R's onto my new ride or just keep the stock springs.
    Rob - Hartford, CT
    Current: 1989 325iS coupe - "Brutus"
    Lachssilber, black leather sports interior, 5 speed, imported to US in 1991.
    Mods: H&R, Bilstein, Brembo, Treehouse, vintage black basketweaves
    RIP: 1984 325e coupe - "Helga"
  • 3bvert
    • 1032
    I dont thnk the sports fit wth stock springs, the rear sport shocks are nearly 3 inches shorter
    at least tath was my justification to get new springs
      • 34847
      no they aren't
      they will be just fine with stock springs, a bit firmer than the OE boges but nothing to be scared of.
      • e30_lover_CT
        • 182
        Cool, good to know. I'll be hanging onto my H&R's just in case :)
        Rob - Hartford, CT
        • 3bvert
          • 1032
          Originally posted by nando
          no they aren't
          months ago I bought a set of sprots for the back,on this forum, and noticed that they were shorter, when fully extended next to the boge fully extended. I put it on the forum, thinking I had gotten the wrong shocks and was told that the sports are shorter and have to use the short springs
          I was told that the HD's were the same as stock.
          that is why I posted the asnwer I did
          if indeed the sports are supposed to be the same length as stock , then I must have the wrong shocks
          ( mines a 318 dont think that makes a diff tho)
            • 34847
            they aren't 3 inches shorter than HDs, which can be used with stock springs
            that was my point
            having a 318 may make a small diff. some of those really sit like 4x4s!
            • Wh33lhop
              • 11705
              Just don't jump the car and you should be okay.
              Let me tell you though, there's nothing worse than having a strut that's too short for your spring. You think bottoming out is bad for your shocks? Try topping out--there's no bump stop to protect it from that. With my old short-bodied konis (I tried them out because some forum whores were jocking them) I topped out a few times over sharp crests and all of a sudden I had no rebound damping. Helloooo oscillation.
              Considering these were actually designed for the E30 though, I think you will be okay.
              paint sucks
              • 3bvert
                • 1032
                ok
                so your telling me that the sports that I bought used here, that are 3" shorter are not the correct shock for my car
                I was told they were shorter because they were sports to be used with short springs and that they came off a 318
                but it sure looks good
                • Wh33lhop
                  • 11705
                  Err.... struts have nothing to do with how low your car sits or how good it looks.
                  Unless you count how stupid you look bouncing around every time you hit a bump.
                  paint sucks
                  • 3bvert
                    • 1032
                    true, I was just thinking if they were the way wrong shock in the back, and 3 inches shorter, maybe they would not allow the car to sit right, like compressing the spring or something
                    • 87e30
                      • Jul 2008
                      • 5676
                      Well since you have both, how about you rip all the stock stuff out put it all next to each other and tell us what you find?
                      I just hate everyone.
                      No need for discretion.
                      • 3bvert
                        • 1032
                        as I stated earlier, the bilsteins were shorter then the stock. I measured them. I know my springs are, they are eibach pro tht I just put in wiht the shocks. the struts are new, the rears I bought used here
                        so I just climbed underneath and looked at numbers.
                        these must be way older then what I was told
                        the bilstein shock number I wrote down, and then went to the bi9lstein site. it came up no number found
                        the number is 0450726 H
                        guess maybe I got burned on the used shocks
                        • 3bvert
                          • 1032
                          this is one of the many threads thta says the sprot shocks are shorter
                          and here is one on this forum that says the sports are shorter
                          • 3bvert
                            • 1032
                            no they aren't
                            so Ive been concerned wiht what I was reading so today I called bilstein in poway ca, talked to sales rep victor
                            yes I have the correct shock, just older then I was told
                            and YES sport shocks are shorter by several inches depending on application, and yes for my 318...3 inches is about correct
                            glad to know I do indeed have the correct "shorter" shocks
                            HD's are stock length for use with stock springs, but the original post was about sports
                            • e30_lover_CT
                              • 182
                              After reading through these replies I think I'm just gonna go with a full transplant of Bilstein sports and H&R's. I feel like I'd be safer with a stiffer setup. My 89 skips all over the road right now if there's rain, but my 84 was a lot more stable in the rain with the HR/Bilstein setup.
                              Rob - Hartford, CT
