:(so i decided to replace my worn shocks and struts.I am able to get to the front shocks but cant pull it out of the casing,seems like the shock is permanently stock in there or something.is there a trick to pull this bad boy out.Any help is appreciated am getting crazy fustrated.
Rookie here needs help!!
Tags: None
The shock may be locked in by corrosion. Liberal application of PBlaster or Kroil and time for it work (hours to days) will help. in stubborn cases heat and gentle tapping all around the strut housing may be required.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, AL -
^ and that shit is going to be rusted in most likely, pb blast that thing and take a plumbers wrench to it!
FREE BITCOINS!! http://qoinpro.com/71690d1639966bfbf223bf16538cec21
Originally posted by scabzzzzI stand up, pull my dick out, and asked my gf to give me some noggin... Well, she starts laughing at me and I freaked out and ran off and locked myself in a bedroom.
2002 325i - DD
2005 Suzuki SV650 - ToyComment
Always remember, a careful application og a propane torch evenly around the edge of the collar will beat any penetrating oil when it comes to breaking that puppy loose!'89 325i track sloot
'01 530i daily
-EnginerdComment
To do this right.
1.) remove the spring
2.) reinstall camber thing
3.) bolt the housing back on the car
4.) heat the area up with the gun, not super hot, jsut enough to help the pb blaster flow
5.) pb blast it
6.) pull with a 2 ft plubbing wrench, both hand on it, and leverage against something.
this method always... and I mean ALWAYS worked for me. did like 6 sets, and some are rusted up and down, and corroded everywhere.Comment
