front spring pad
  • rede30
    • 4697
    front spring pad
    how much drop would a person get if they took of the front spring pad. i would like a small rake to my car when i lower it thanks.
    Dustin
  • Chris E30 Cab
    • 866
    just add a thicker pad to the rear, then you won't have to run without spring pads ;)
    • Mystikal
      Wheel Fitment Expert
      • 9602
      6mm IIRC, not enough to make it worth the effort. Like Chris said, add to the back.
      • Digitalwave
        is a poseur
        • 6300
        6mm = 1/4. Considering the pads are smashed from age they probably aren't even 3mm each anymore... its not really noticable. Won't make any rake thats for sure.
        RISING EDGE
        • Old'n'Slow
          • 436
          Yep! They come in 5, 7.5 and 10mm thicknesses. The amount of lift will be slightly more because of the geometry of the trailing arm.
          WAY easier than playing around with the front!
          • rede30
            • 4697
            alright cool thanks guys.
            D
