e30 m3 vs standard 325 strut tubes
  • Colorlesss
    • Jul 2009
    • 570
    just the strut tubes themselves. are they the same ? obviously cant check real oem or anything similiar to check PN's
  • White325is
    • Oct 2006
    • 5947
    no, the spindle is different. But I know what your thinking, The bearings and hubs wont bolt up.
    • hoveringuy
      • Dec 2005
      • 2743
      I know the M3 struts are different because they share the e30's 6" diameter springs. Normal e36's have larger springs.
      I have also heard that the '92 e36 struts are actually the same as the later M3 struts, but cheaper. True/False?
      • Gooch
        • Dec 2006
        • 1674
        Also, the e30 M3 strut housings have a removable tie rod knuckle that bolts to the bottom of the strut housing with four bolts. The regular e30 strut housings have the tie rod knuckle integrated as one piece with the strut housing.
        But regardless, you can't take an e30 M3 hub and bolt it onto the e30 housing...the spindles are different and a larger nut holds the M3 hubs onto the spindle.
        '91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
        '87 535i - Vacuum brake conversion [SOLD]
        '93 525iT - 5-speed swap - 320k and counting
        '09 328xi - 6-speed
        • Colorlesss
          • Jul 2009
          • 570
          you guys arent getting what im asking. i am asking about just the main tube, not the spindles. i know the m3 spindles are completely different.
          if you had an e30 strut housing and an m3 housing .. and cut the spindles and all mounts off both .. would the tubes themselves be the same ?
          • Gooch
            • Dec 2006
            • 1674
            The e30 M3 has the sway bar tab on the tube while regular e30s do not. The sway bar tab can be easily purchased from AKG and welded on.
            Diameter is the same as the late model tubes (51 mm IIRC). Length is the same.
            '09 328xi - 6-speed
            • Colorlesss
              • Jul 2009
              • 570
              ya the AKG mount is what i had planned to do. but i need to know if the tubes are the same before i buy the parts
              • Aptyp
                • 6584
                e30 struts fit inside of e30 m3 struts, that was his question
