Car sitting lower on one side.
    • 37832
    The rear of my car is sitting 1/2 inch lower on one side, can anyone explain this or tell me what may cause this?
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
  • e304lyfe
    • 807
    .........bad springs?
    • Rob
      • 8166
      tire pressure? different tire sizes?
      BEERTECH
        • 37832
        Well, tires are the same, pressure is fine...
        Could a spring more or less "go bad"? I have H&R Sports
        Grover Beach, CA
        www.BimmerHeads.com
        • Rob
          • 8166
          premature spring pad wear on one side?
          BEERTECH
          • e304lyfe
            • 807
            bent trailing arm?
              • 37832
              Well, I will inspect it a bit more now that the car is disabled anyway. I'll check it out today or tomorrow hopefully
              Grover Beach, CA
              www.BimmerHeads.com
              • robert325is
                • Aug 2004
                • 1171
                wherever your car is might be tilted
                • Rob
                  • 8166
                  maybe whoever did the suspension left out a spring pad
                  BEERTECH
                    • 34839
                    spring pads aren't 1/2" thick, rob.
                    my vote is a bent trailing arm.
                    • E30-323ti
                      • 328
                      Mine use to sit uneven with my old (I mean "old") springs & trailing arms.
                      Just put in new trailing arms & springs (5lug swap) and it still sits uneven, not 1/2" like yours, maybe ~5mm max, but enough to piss me off!!
                      292rwhp E30 :D
                      • trent
                        Originally posted by e304lyfe
                        bent trailing arm?
                        I would guess the same thing and subframe. Even though the rear of your car cannot be aligned, take it to an alignment shop and have them check everything.
                        • Rob
                          • 8166
                          maybe they accidently left both pads out of one side and doubled them up on the other...
                          BEERTECH
                          • ///M42 sport
                            • 3952
                            My car does the same tine. about 1/2 inch lower on the passenger side.
                            • bmwm3n528
                              • 3654
                              Maybe you need to do a CSL treatment...to yourself
                              Trevor Ely
                              '95 M Sport 540i - '00 A4 1.8TQMS - '85 190E 2.3-16
                              '88 535is - '87 325e - '89 325is - '91 318is - '90 325is - '96 328is
