Bigger rear sway bar...
  • Hellabad
    • 807
    Originally posted by lifeiskaos
    Cabrio bars are the same diameter as m3 bars
    Not true. Cabrio bar is biggest diameter, M3 bar is smallest diameter.
    The cabrio bar idea is good, but they are hard to find because all of the yuppie girls are still driving them after their first divorce, in hopes of remaining attractive to the pool boy that they don't have anymore (since the divorce).
    Here is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
    Ground Control Gallery
    The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
    • FredK
      • 14763
      Yuppie "girls" still drive 1987 325iCs?
      I think we have a term for that these days.
      Senior citizen. PM member "blunt" if you want tips on how to trawl the dangerous and adventure filled seas of your local nursing home.
      • lifeiskaos
        • 1709
        What size are m3 front bars? I wonder why I always thought they were 21mm...
        I could get cabrio sway bars all day long at scrap yards here in Socal...
        • gearheadE30
          • Jun 2007
          • 3734
          both M3 and cabrio bars are 21mm. The cabrio bar has slightly different geometry which makes it effectively stiffer on standard swaybar links.
          Project M42 Turbo
          • browntown
            • Jun 2004
            • 3524
            I run cabrio bar with m3 adjustable front links welded to strut tubes and a m3 rear reinforced with IE's kit. When I made those decisions it was talked about as the stiffest bars you could get out of the e30 bmw parts bin without going aftermarket. Further it has been said that the m3 link geometry off the strut vs off the control arm effectively increases the power of a thinner bar.
            I didn't pay a lot of attention in college, so I can't confirm any of that. Used to be pretty common thinking though I thought.
            • D-rock
              • 714
              wouldnt you upgrade both since they come in a kit? Or are we talking about strut braces?
              • Wh33lhop
                • 11705
                I've read time and time again that M3 front bars are 19mm. With the M3 endlink setup I believe they're more effective than the cabrio front bar with standard endlinks.
                paint sucks
                • gearheadE30
                  • Jun 2007
                  • 3734
                  You're right. This is eventually what I will be running as well, but I've been too lazy to pull the strut housings and everything.
                  Project M42 Turbo
                  • weaksauce
                    • Apr 2009
                    • 550
                    StabilizerD=19MM31352225284$162.98
                    from real oem
                    87-90 m3 19mm
