Anyone using shocks made for non-bmw car on their E30?
 Any chance youd know the part numbers or the exact model commodore (fronts) and falcons (rear)???if the kyb shocks you have are like those bilsteins with the spring seats and mounts welded to them, you will not be able to modify them successfully for use in an E30. Witha sealed shock you won't be able to effectively weld to the shock body.
 regarding your question.
 I run Holden Commodore (similar to the new Pontiac GTO) strut inserts in the front of my E30, they are 30mm shorter in length.
 And have Ford Falcon shocks in the rear. These are short enough to just keep a 140mm long spring captive in the rear.
 ive heard that the VT commodre on the rear work well too... but u need to shorten as well..
 ill have to look into the mustang as well....
 thanks in advance
 :)Signature removed by R3V staff due to a violation of the forum rulesComment
 none of the suspension on my car is from a BMW. The fronts are Camaro and the rear are inverted shocks for a truck...
 Obv all have been revalved for my application///Alpinweiß II 24v 91' 318is, Alpinweiß III 99' 323i, 04' Yamaha R6 SE for sale, 00' VW GTi, 83' El Camino BURNED, 01' P71sold, 92' Miatasold
 Guys!! I bought f4-b46-1102-h0 type 10 bilsteins off eBay
 did a parts looks up and they are listed for a daihatsu rocky(4x4)!
 Installed them lastnight on a lowered 325is, works amazingly!!! I just need to find which commodore insert works best for a lowered application up front with high spring rates..550lbs
 sashSignature removed by R3V staff due to a violation of the forum rulesComment
 sash
 what spring rate is in the rear?
 "Hard Work Pays Off"
 1991-bmw 325i (R3vvd)
 1990- 325 (mpowa)(GC)(track)(beast)
 1988- 528e (daily driven when track car broken)Comment
 im running 600lbs rear, 550 up front.... front is too firm for my shocks... so im looking into what i can use now... rear feels amazing... id like to see what improvements ppl get with these on the track!Signature removed by R3V staff due to a violation of the forum rulesComment
