I have been looking for a spring that would work with the Bilstein sports on my S52 swap car for the past couple of months.
Having tried the Eibach Pro kit and now the H&R Sports to be lacking in enough spring rate to support the extra weight of the S52 without bottoming the Bilstein Sports, I am going to try to some things used by mainly dirt track cars (sprints, etc).
I'm going to try some spring cushions first to see if they will provide the extra stiffness I need, if that doesn't work then I'll try the springs. The cushions come in rates between 10 and 75 lbs. I'm going to try some 30 lbs ones first and see how they work. These will raise the spring rate to approx 210 lbs/inch.
There is also a huge selection of springs available out there, and they match the specs of the E30 springs (diameter, length, etc) pretty close.
The best thing is these pieces are not expensive at all; the cushions only cost me $80/pair and springs are only $120/pair...
Should have the cushions in place by next week.
